Ecounter a fatal io error?
I have encoutered a fatal IO error when running the 2d domain/longer pipe run at https://www.simscale.com/workbench/?pid=3253427884872203341.
What were changed are:
  • Longer pipeline
    • Before: 50cm
    • Now: 500cm
  • A piecewise function for velocity inlet BC instead of a number.
    • Before: 20m/s
    • Now: (2000*t+10)*(t<0.004) + 18*(0.004<=t<0.008) + (-1000*t+26)*(0.008 <=t<0.016) + (250*t+6)*(0.016 <=t<0.02) + (500*t+21)*(0.02 <=t<0.024) + (2750*t+57)*(0.024 <=t<0.028) + (-1250*t+55)*(0.028 <=t<0.036) + (-1500*t+64)*(0.036 <=t<0.04) + (3000*t-116)*(0.04 <=t<0.044) + (-1500*t+82)*(0.044 <=t<0.048) + (2000*t-86)*(0.048 <=t<0.052) + 18*(0.052 <=t<0.056) + (-1000*t+74)*(0.056 <=t<0.064) + (250*t-6)*(0.064 <=t<0.68) + (-500*t+45)*(0.068 <=t<0.072) + (2750*t+189)*(0.072 <=t<0.076) + (-1250*t+115)*(0.076 <=t<0.084) + (-1500*t+136)*(0.084 <=t<0.088) + (3000*t-260)*(0.088 <=t<0.092) + (-1500*t-154)*(0.096 <=t<0.096) m/s
    • t is time
What is the cause of this error?
Thank you
Hello yapabox589,
I’m not quite sure but do you check if the function is defined correctly. What I would suggest is to instead of a function is to use a table.
This will have the same effect as your function, but you are sure that it’s defined correctly.
please let us know if this worked for you?
Deleting my answers. This page helps me set up everything
