Duplicating Contact Pairs
Selecting contact pairs has always been a bit cumbersome in FEA… Of course an auto generate contact algorithm would be great, but in the mean time can we just duplicate a given contact pair? This would save a lot of time in the example of a Printed Circuit Board with surface mount components, where one of the contact pairs (the top of the board, or example) is common throughout. Thanks!
Hello @fastwayjim,
Have you tried the Topological Entity Sets?
This are useful to give a reasonable name to the surfaces and reuse them through the simulation definition, for example:
Hope this helps you.
I have, thank you!
It definitely saves some time during selection, however I first made the mistake of creating them in the Geometry instead of the Mesh. Ugh.
I really, REALLY, wish there was a parametric tie between the Geo and the Mesh in Simcale. For those that use Simscale as a “design tool”, and thus plan on many geometry changes, it is critical to have that link.
@fastwayjim, great input - keep those suggestions coming.
  • Could not agree more on how valuable associative topology handling will be! It’s very high on our priority list and we’re working aggressively on it! Stay tuned on that one!
  • Duplication of contact constraints should be fairly simple enhancements - I’ll check if we can bump this up in priority. In fact duplication of boundary conditions will be release shortly
Awesome! Can’t wait!
Okay, nevermind. Just a learning curve issue on my part… I just created a single contact set with many slave surfaces, using the board top as the master (per the electronics tutorial, duh!).
