From function checkMethod(const fvMatrix<Type>&, const GeometricField<Type, fvPatchField, volMesh>&)
in file /home/vishnu/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude/fvMatrix.C at line 1356.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 void Foam::checkMethod<Foam::Vector >(Foam::fvMatrix<Foam::Vector > const&, Foam::DimensionedField<Foam::Vector, Foam::volMesh> const&, char const*) in “/home/vishnu/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/simpleFoam” #3 in “/home/vishnu/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/simpleFoam” #4 in “/home/vishnu/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/simpleFoam” #5 __libc_start_main in “/lib/x86_64-linux-gnu/libc.so.6”
Hi All, you wont get any vanilla openFOAM to run a SimScale run out of the box, 2.3.1 is the closest. What you saw above is the fact that incompressible simulations in vanila openFOAM are normalised by density. as that is how it is usually solved. To make our solver more user friendly we deal with pressure as a real physical unit (Pa) and therefore when openFOAM does the check to ensure the units are correct, it finds they are not. You can simply change the units in your initial conditions in this case I believe.
