Diverging Velocity Field
Hi
So, as the title suggests, the velocity field started to diverge. I tried refining that area but it says certain mesh qualities/metrics were still within the recommended range. I’m still pretty new to CFD in general so I am not exactly sure how to approach this problem and hopefully anyone knowledgeable about this (especially SimScale support) can assist and point out what I have to do. Thanks. Screenshots with descriptions below:
This one says I have quality metrics outside the recommended range (probably what’s causing the velocity field divergence)
The actual problem:
Link to the project: SimScale Login
Thanks in advance!
I’d suggest that you follow typical troubleshooting steps here. If you follow the steps carefully, you will notice a handful of very small faces around the divergence point, which I would suggest that you clean up in the CAD model.
