Condensation over tubes heat exchanger
My project is very similar to the famous heat exchanger which can be found in the public projects already and it’s setup is done the problem is i want to add a phase change process over the tubes which means that the steam will condense over the tubes what should i add to the setup
thank you,
Hey,
Currently there’s no way to model phase change within SimScale, unfortunately! There’s a feature vote for it though, I believe: Phase change in Multi-Phase Flow Simulations
