I’ve designed a mould with an injected aluminium inside (considering solid at 1036 ºC). I have made a pipe inside the mould where the water flows acting as a cooling fluid. But, I have found that the design doesn’t affect to the refrigeration. I mean that changing the number of the pipes, the diameter or the speed of the fluid doesn’t affects to the heat variation in the mould or in the nucleus. Also, the outlet temperature doesn’t increase so much although the global temperature of the mould is 90 ºC and the nucleus 1036 ºC. Is this invariability correct or I forgot to change something in simulation?
I think it’s probably about numerics. I have decreased the solid enthalpy tolerance but I don’t know if I must change some other parameters.
I attach some links with some of my designs. Thanksfully.
1 vertical curved pipe: https://www.simscale.com/workbench/?pid=673818097472781090&rru=0d06e370-c3a4-4cbb-9333-cbb8b69e2493&ci=48b70fc6-351a-45a6-8f30-478aa8b94d06&ct=SOLUTION_FIELD&mt=SIMULATION_RESULT
5 side straight pipes: https://www.simscale.com/workbench/?pid=6341611375166611563&mi=spec%3Aa1152e0f-3674-484f-9b27-c7a78d551054%2Cservice%3ASIMULATION%2Cstrategy%3A41
3 side straight pipes: https://www.simscale.com/workbench/?pid=7771950681641868902&mi=spec%3A15ac38d3-1562-408c-b3ca-c58b27ff4794%2Cservice%3ASIMULATION%2Cstrategy%3A6
1 side straight pipe: https://www.simscale.com/workbench/?pid=4840923060765972691&mi=spec%3Aebbed619-c60b-4b16-98e5-d60fc4c3f822%2Cservice%3ASIMULATION%2Cstrategy%3A69
