Hi Retsam,
Thank you for your helping hand. Do you know Maximum Time Afloat MTA boomerangs ? They are very different from long distance boomerangs. Long distance boomerangs circle around 40 meters but MTA world record is 298 meters and people reports about lot more distance experiences.
World record owner is my friend and I know the all important people in the sport.
MTA boomerangs are stange. When you throw them in normal weather , they fall after 40 meters.
But when you throw them in a thermal hot air current , they follow the thermal whereever it goes. Some people loses their unending flying boomerangs after one hour flight , they follow with motorbike.
I found some company did what I want as a experiment but they selected the shortest range flight.
They used matlab as trajectory calculator , catia as shape changer , siemens as cfd simulator and optimizer software to bridge everything together.
I could use fluent as cfd simulator but gpu cards are very expensive.
Now the question , does simscale have a capacity or ready softwares to do as above 4 softwares?
Are they free or rent for hourly rate. I found a dresden company hpc and they wanted 22 euro per software per hour.
I looked in to simscale drone propeller optimization and it was only for higher lift
, turbulence , wake , interaction of blade tip flow with wake , stall, turbulence creation , lose of lift coefficent by turbulence had not been optimized and told. Shape change was I think comparison of two designs.
If simscale will only optimize for better airfoil lift, its been done with XFOIL free.
And I want the thermal been in the optimization process
Are these simcale can offer and what would be the cost. Cost is very important .
I can offer a 1 year of course but I must know what to offer where.
Umut
