Aerodynamic Analysis of Non-pneumatic tires - Pressure divergence
I am a beginner and I’m doing a project on non-pneumatic tires in which a CFD analysis is performed. I have completed all the steps and started the simulation process>however, I am getting an error as shown in the below image
I have also attached the link to the project below. Hoping to see your reply soon.
Hi there!
You missed to assign one of the slip walls:
This means it was automatically set as a no-slip wall.
Other than that, divergence seems to occur contact patch of the wheel with the road.
(I used the Isovolumes method described here: How to Check and Improve Mesh Quality | SimScale)
I suggest you increase the gap between these two surfaces, like in the vehicle tutorial here:
Let me know how it goes :smiley:
Thank you so much!
So after assigning the third slip wall the mesh has to be regenerated and a new simulation has to be run right?
If the physics-based meshing is applied, then I recommend you recreate the mesh and then create the simulation :slight_smile:
