My project: SimScale
There’s a building and a fluid region. Recommendations say to use advanced options (supposedly for my building? But i do not want any of the advanced options (they dont make sense, the building is there and i just intend to measure pressure around it)
Since incompressible analyses require a single volume to run the simulation, the fix to this problem is to go back to CAD mode, run a “Delete body” operation, deleting the solid block in your CAD model:
The result will be a single volume representing the flow region. If you use the new geometry to run the simulation, you will not run into the same error message.
Please refer to any of the tutorials on external aerodynamics for more information.
Thank you very much,
I implemented that in a private copy and indeed it works (i just didnt know if it messed around with results).
