Okay, I have strange question: why I can’t see Y plus values in compressible simulations (air)? I’ve done the same simulation (the same mesh; don’t care about the results as values at this stage) as both in- and compressible case and:
Incompressible | I downloaded results, opened them in Paraview and at the very first step (zero) I was able to display Y+ values.
Compressible | I did exactly the same thing here and Y+ was not there – why?
Hi Maciek,
thanks for noticing this. Compressible and incompressible analysis types both should now calculate yplus if set as a result control item. There are a few missing corner cases, e.g. compressible LES, that we want to wait for fixes in a stable release before adding them to the platform. Apart from that, go ahead and add yplus to your simulations!
Babak
@anon5767293 thanks for reporting and thanks @gholami for fixing this!
@gholami Thanks for info, but I’m afraid it still doesn’t work properly. Yesterday, after your post I run new simulation and yet again in Paraview I saw only Y (without plus and values, or with some strange illogical ones).
Today I’ve just run another case – this time very simple in order to save some core hours – and now I see Yplus but there are still no values in compressible simulation (air by default). Therefore would you be so kind and take a quick look at this:
https://platform.simscale.com/?publiclink=a59a3219-e662-4fac-8a64-20417ca57382
@Maciek, thank you for trying again. I had a look at your project and it helped to trace back the problem to a solver data management issue. It is now fixed and you should be able to get yplus consistently, this time for real
