I am starting to use this simulator, i am very new to CFD and to SIMSCALE
I ve transfered a pond design from onshape, and looking how this simulator perform, the thing is for some reason, I get the following error:
“A multi-region mesh was assigned - this analysis-type requires a single-region mesh”.
I tried many configurations.
The project is here: https://www.simscale.com/workbench/?pid=9207996278568178168
My last Config. with a material mesh configuration, and the point inside the water volume, resulted in a request to use the mesh as domain, which happen to delete all the structure holding the lagoon and the inlet outlet pipes.
I would be grateful to be offer any advise. Feel free to ask any question.
I only want to check dead zones, and the flow profile, using 3 inlet pipes and 3 outlet pipes, at constant water level to start.
