I created this project to simulate the cooling of an electrode using a simple water block.
I am facing some issues with how to create the pipe flow of the water inlet and outlet.
Should I create a flat face in my geometry so I can select it as a inlet face. As previously I
created a hollow pipe in, through the block (Uturn) out, and I could not assign the water inlet
and outlet face properly to do a simulation.
Meshing also turns out to be difficult as the face is on the same plane If I did a flat face one of
the outlet would not be selectable.
Please advise on which is the best approach for such a geometry.
