Volume ratio room for error?
Hello, I was wondering if the volume ratio under 100 absolutely has to be under a hundred because there is this one tiny piece in my mesh that has a volume ratio of 100.152 will this affect my results from my simulation?
thank you for your help,
Frank Lucci
Hi Frank,
It should work, please test with a run. If it doesn’t work, then you can refine the region with the high volume ratio.
