Hello everybody,
for a school competition, we simulated two model car designs, which are very similar. Somehow, the first Model (DE-06.08.07.03) has a much lower (even negative) lift value (pressure z) in comparison to the second model (DE-06.08.07.04).
I think I may have made a mistake in the simulation setup but can’t seem to figure it out.
First model: SimScale Login
Second model: SimScale Login
Any help is appreciated!
Daniel
Hi Daniel, I’ll take a look at your case and get back to you later ![:slight_smile: :slight_smile:](https://frontend-assets.simscale.com/forum-assets/master/emoji/twitter/slight_smile.png?v=12)
Hey Daniel, can you post a reply to this post with the comparison between the results you mentioned? From my end, I don’t see a big difference in the pressure, but maybe I’m looking at the wrong plot! ![:slight_smile: :slight_smile:](https://frontend-assets.simscale.com/forum-assets/master/emoji/twitter/slight_smile.png?v=12)
m
Thank you for investigating!
I mainly noticed the difference in the force plots, which you can see in the images below.
Normally, the lift values for our models lay between 0.050 and 0.100
Hi Daniel, I noticed that there’s a wrong rotating axis for the wheels on the first model (x should be 1 and y should be 0, as per right-hand rule). The second model is showing the lift values you expected, right? However, still I think the value of the rotating axis should be x = 1, not x = -1. What do you think?
Maybe that can improve the results!
Thank you! You are correct on both of those things I assume.
