I’m a newbie to SimScale, trying to understand the flow rate option for velocity inlets.
If you set a constant flow rate for a velocity inlet, is the rate of flow effectively the same at any point on the inlet’s surface?
Thanks.
Thanks.
Hi @spacemanspiff,
Thanks for your question and welcome to the forum Yes, your statement is correct.
You might also find this post helpful
