Unstable convergence plot at inlet and outlet
  1. I am having a set up of impeller which is enclosed in an enclosure & in boundary condition I have specified velocity inlet and pressure outlet. an impeller is rotating at 2920 RPM I want to check the total pressure drop at the inlet and outlet.
2 after running my study if I check the convergence in the inlet and outlet. it seems that the beginning result is stable but in the end, suddenly it becomes unstable.
  1. I have checked with increasing time steps for a simulation run but still, I got the same plot
Project Link:
Hi, this is Fillia, thank you for using the forum.
I have two suggestions:
  1. Toggle on the potential flow initialization option prior to the run:
  2. If this still does not work, consider using a Mean instead of a Fixed pressure value on the outlet:
Hi Fillia,
thank you for the response.
Can you please elaborate on point no. 2 (what is a fixed value and mean value).
and when should we consider fix/mean value
Have a look at the bottom of the page here: Pressure Inlet and Outlet | Boundary Conditions | SimScale :slight_smile:
Thank you Fillia, it was helpfull.
Hi Fillia,
I ran 3 more studies as per your suggestion.
  1. Turning on potential flow initialization.
  2. Potential flow initialization + pressure outlet mean value.
  3. Only pressure outlet mean value.
But still i got same convergence in all of the cases at inlet and outlet.
Project link:
I even tried increasing simulation time but still, I got the same unstable residual at the inlet and outlet face of my model.
I did check related training files available on the Simscale I did not found anything different in it.
Should I believe in this result with convergence plot like this?
