Unreliable results for water flow in thin pipe
I’ve been trying to simulate water flow through a thin pipe.
An initial attempt worked well and I got a result that was in line with what I was expecting.
first attempt
Then I slightly changed the shape and the results became very weird, the speed was 20 times as high and I don’t understand the reason for that
second attempt
I don’t understand what I’m doing wrong and would appreciate any input!
Also, isn’t it necessary for turbulent flow to know how rough the surface of the pipe is?
Thanks and best wishes,
Kevin
sorry, I just saw that the question was already answered 5 days ago.
My ultimate project contains 2 inlets and 1 outlet though and also fails to converge:
third attempt
What is the recommended approach with three openings
Kevin
Hi Kevin!
All runs finished fine - where do you see the problem? Only in the convergence plot for run 3? Do not put all your hope into convergence plots, they are a good indicator of how the simulation goes but no guarantee that the simulation will actually give you correct results or that they make sense physically.
Thank you Jousef, I’ll keep that in mind!
