I’m simulation an air flow trough a duct, but I’m seeing unexpected behavior. The core of the air stream has an eccentric position at the outlet. Does anybody have an Idea why this is happening?
Best
Leon
Best
Leon
Hi @ketscher,
Thanks for posting your question, and sorry for the late reply.
As you said that you are expecting a dimetric flow pattern, I recommend to apply the symmetry BC, dividing the domain by 4 decreasing the computational cost.
Furthermore, I ran a setup with an hexahedral mesh, which provides a flow more close to the symmetry than the set-mesh, and also using a transient flow to see if there are any changes in the flow pattern through the time. The results you can see below, and I hope this helps.
