Tutorial: Aerodynamics Simulation of Flow Around a Vehicle
but at step 1-3 I was not able to create the “Topological Entity Sets” As it is greyed out and when I hide the domain walls, nothig is displayed… Please help!
Thanks,
Hi, thank you for using the forum! As you can see at the right of the screen , the ‘Flow region’ is hidden.
Try the following:
Right-click on the workbench and choose ‘Show All’. Then all the faces of the domain should appear.
Manually select the six walls of the domain, right-click on the workbench again, and choose ‘Hide selection’. Then only the faces of the car should appear.
