I am simulating a tool assembly (Extrusion Die and Head) made of dissimilar materials. The goal is to observe how differential thermal expansion causes the initial contact interface to separate (opening a gap), and how this separation affects the heat transfer between the two components.
Initial Condition: Components are in contact at t=0.
Loading: Internal pressure ramp and thermal loading to operating temperature.
Contact: Physical Contact with “Enable Heat Transfer” set to Yes.
Current Issues:
Singularity & Stability: As soon as the components begin to separate due to thermal expansion, the “floating” component (the Die) loses its primary constraint, leading to rigid body motion errors and solver crashes (Parallel Process/Matrix Singular errors).
Thermal Discontinuity: The solver struggles with the sudden drop in thermal conductance as the contact transitions from “Solid-to-Solid” to a “Gap” (Air/Vacuum).
Hardware Constraints: The high mesh density required to resolve the contact interface (approx. 0.01m on a 40cm part) combined with 2nd-order elements is causing “Out of Memory” errors on standard computing nodes.
Steps Taken So Far:
Implemented Automatic Time Stepping to capture the non-linear contact transition.
Applied Load Ramping via tables for both pressure and temperature to improve convergence.
Added Surface Refinement on the contact faces.
Ensured no conflicting “Bonded” contacts exist on the same faces.
Seeking Advice On:
Stabilization: Best practices for using Elastic Supports (artificial springs) to prevent rigid body motion without over-constraining the thermal expansion.
Contact Stiffness: Recommendations for scaling contact stiffness (Penalty Factor) to ease convergence in metal-to-metal separation.
Thermal Gap Conductance: How to realistically model the thermal transition when the gap opens to prevent numerical oscillation.
Rigid body motion: Add very soft Elastic Supports/Weak Springs to the die (or enable solver weak springs if available). Set stiffness several orders of magnitude lower than the structural stiffness so they only stabilize the model after contact opens.
Contact stiffness: Start with Program Controlled or reduce the penalty/contact stiffness scaling (e.g., 0.1–1.0× default) to improve convergence during separation.
Thermal gap conductance: Use a thermal contact conductance that varies with gap distance/pressure rather than an abrupt on/off transition. Include gap conduction (air) and, if temperatures are high, consider radiation across the gap.
Memory issues: Use local mesh refinement only at the contact zone, switch to 1st-order elements where acceptable, and consider symmetry/submodeling to reduce DOF.
To build on Maissa’s excellent theoretical advice, here is exactly how you can implement those fixes natively within the SimScale environment:
Stabilization (Elastic Support): To prevent the singular matrix error when the Die separates and loses its primary constraint, add an Elastic Support boundary condition to the outer, non-critical faces of the Die. You need this to be a “weak spring.” Try setting an isotropic total stiffness of around 1,000 to 10,000 N/m. This provides just enough mathematical resistance to satisfy the matrix and stop rigid body motion, without artificially restricting your thermal expansion.
Contact Stiffness: SimScale defaults to the Penalty method. If the separation is struggling to converge, try switching the contact formulation to Augmented Lagrangian. It handles the sudden transition from solid contact to a gap much more gracefully. If you prefer to stick with the Penalty method, explicitly reduce the Penalty coefficient by an order of magnitude in the settings to soften the interface.
Thermal Gap Conductance: Instead of a static on/off value, you can make the thermal contact conductance gap-dependent. In your Physical Contact settings, change the thermal conductance input to Table. You can then define a curve where the conductance is high at 0 mm clearance, and drops off drastically as the clearance increases, properly simulating the insulating effect of the newly formed gap.
Memory Issues: A 10 mm mesh on a 40 cm part using 2nd-order elements will easily exhaust a standard cloud compute node. Before committing to that density, run the simulation with 1st-order elements first. Use this lighter mesh strictly to validate that your contact separation and thermal gap physics are converging properly. Only switch back to 2nd-order elements once the non-linear setup is perfectly stable.
