I created a new simulation project called 'structural ':
simple loading analysis
@javal_ipr_ext - if you want to run a loading/structural analysis of the vessel, I’d recommend going with the “Automatic tetrahedralization” mesh operation. The snappyHexMesh mesher will give you a polyhedral mesh that you can not use for Finite Element analysis (only for finite volume / CFD).
Hi @javal_ipr_ext!
Great effort! you know you can perform quite nice simulations with pressure vessels like this. I have performed one of the thermomechanical analysis here: Pressure Vessel Thermomechanical Analysis by ahmedhussain18 | SimScale.
First since it was a structural analysis, I meshed it using an Automatic tetrahedralization with moderate mesh refinement. Since it’s a pressure vessel, it makes more sense to do a thermostructural analysis in order to see the stresses formed inside this vessel both due to internal pressure and temperature. Therefore I selected “Uncoupled thermomechanical analysis” and steady-state due to simplicity considering that we are simulating the final response.
I than defined steel as a material for the vessel. I applied the pressure and temperature of 1 MPa and 573.15 (300 °C) repectively on the internal surfaces while keeping the vessel constrained from below, sides and top portion. I also applied the convection due to outside air to the external surfaces. I ran the simulation on 4 cores and it just took 1 minute to complete.
The figures below show the results of temperature, heat flux and vonMises stress respectively. The geometry deformation is scaled by 10 times here to show a little distortion. In last figure, through a cutout one can see how the vessel is deformed from top and bottom. One can apply more pressure and internal temperature to see more deformation. As a next step, you can also perform a transient analysis with increasing internal pressure and temperature with respect to time. For this you can have a look at: Thermal Structural Analysis of a Pressure Vessel by ahmedhussain18 | SimScale
Great sim, @ahmedhussain18!
Thanks @dheiny!
Hello, I am interested in your project, and would like to know please your aim on this project. Were you looking to test different steel thicknesses?
Leo
