- An error occured in the projection of contact nodes because of an empty contact node list. Imprint your CAD model using the respective geometry operation from the geometry context menu and retry. In case the model is already imprinted, you can try to increase the position tolerance value in your contact settings.
Hello ram863,
thanks for reaching out to us here in the forum. To help you with your issue. can you please share a link to your project and provide some information about your simulation and what results you want to achieve?
Thanks and best regards
