Hi @nvashi,
I mean in the CAD program itself. If you struggle merging the components, write me a private message. I will try to merge it with Creo 3.0.
Hi @nvashi,
Moved conversation with @nvashi to private.
I got this error while running the simulation:
“The job execution was aborted, possibly due to a numerical instability. Review the log to identify reasons: unphysically large field values, extremely small time step size, etc. Modifying numerical settings and time step size could resolve the issue.”
Someone knows how to fix it?
Hi @andresuriegas,
counter-check the parameters you typed in. If the error is still there, let me know.
I’m running the mesh again, I had one value slightly different, I’ll let you know if it worked. Thanks
@anon67859130
Hi, in session 2 you said you would provide us with a tool to calculate k and omega in the final session, I have skipped through video 3 and 4 yet I have not seen anything regarding calculations or equations of k or omega. Please guide me to the location of the tool or a reference to calculate k and omega. Sorry if I missed it in the video, I am doing an assignment on design of a road going race car and I am using the videos as reference to perform CFD simulations using Simscale. All I could find on the web was this:Turbulence free-stream boundary conditions -- CFD-Wiki, the free CFD reference but the values I calculated do not match yours
Thanks so much
Hello, I tried one wing setup with different resolutions of the stl files. There is a huge difference in lift/downforce (-131/110) and a rather small in drag (26,8/24,8).
Simulation 1_FW_V4 vs. Simulation 1_FW_V4_fine
Is such a high influence of the resolution realistic?
Thank you in advance.
Kind Regards
Andreas Fischer
Hi Andreas (@andreas_fischer),
looking at the plots in the second run (the fine one) it seems that they are not really converged. Can you try running it for a bit longer?
Tell me if that had some influence on your results.
All the best!
Hello Jousefm,
I tried it with a longer run time and the impact on the result was pretty big:
Simulation 1_FW_V4_fine_Runtime: Drag 28,1 Lift -140,0
The task was to increase the downforce and the efficiency compared to the front wing in the second homework.
For the wing of the second homework I got 19,67/-112. Is that a realistic result for the comparison?
Kind Regards
Andreas Fischer
Hi @andreas_fischer!
Let me get back to you soon. Will have a look at the simulation and see if you can work with the results.
All the best!
