Hi, I’m performing a linear static structural analysis of a Formula Student brake disc in SimScale.
My previous runs failed with machine out-of-memory errors, so I reduced the mesh and changed from 2nd-order to 1st-order elements.
Current mesh:
- 1st-order tetrahedral elements
- 116,906 tetrahedra
- 28,843 nodes
- SimScale reports that the mesh meets quality criteria
Current simulation:
- Linear static structural
- AISI 420 stainless steel
- Young’s modulus: 200 GPa
- Poisson’s ratio: 0.27
- Density: 7750 kg/m³
- Fixed support on six mounting-hole cylindrical faces
- Remote moment: Mz = 328.8 N·m
- Centrifugal loading corresponding to 158.4 rad/s
Run 5 has been running for approximately 28 minutes but remains at 0%.
The Event Log only shows:
“Job was prepared successfully.”
However, the Solver Log shows:
86,544 degrees of freedom
86,544 × 86,544 linear system
Chronos using 2 threads
matrix fill rate approximately 0.049%
Is this expected solver behavior at this stage, or could the simulation be stuck during matrix assembly/solution? Is there anything I should change regarding solver settings or compute resources?
