The meshing failed as the mesh fineness is too close to the model tolerance of the following entities: edge3447@Flow region. Try to optimise the model tolerance with your CAD tool. Also, if any Refinements are defined on those entities, try to increase the mesh size, otherwise please contact our support for assistance. However the same model i have been used successfully before with the same mesh setup.https://www.simscale.com/workbench/?pid=3690833675442415852&mi=spec%3Ac51c4efe-051e-43ab-b4ed-0b54090f436e%2Cservice%3AMESHING%2Cstrategy%3A559&sh=543
Hello tilloyev_murod,
I can see that in the project you have a simulation currently running.
Were you able to solve the Issue?
Hi sir yes, it was because the small feature suppression was to high
