Hello, I succeeded to get through with the mesh.
I would be grateful for your help now, because I realise lots of questions arise.
1 - Concerning the rotational sens of the turbine, the right hand rule apply and to make it turn in the other sens i just put a minus before the rotational speed, correct ?
2 - Then when I look at the result the airflow direction heading to the support of the wings surprise me, did I do it wrong ? The goal is to simulate a rotating turbine in a low turbulence, indoor , environment.
3 - I can’t adjust the rad per second / rotational speed to visualize the difference in velocity and direction of the air flow. Can it be done at will after the simulation and where can I find the chart describing it ?
4 - I did particles trace for visualization, but it seem wind can only come form a point in space. Goal being to see the perturbation in the air caused by the turbine/fan in normal conditions/ indoor , therefore it should affect all the volume of air around it in 3 dimensions, a kind of iso volume with lines.
I join the link : SimScale Login
Thank you vey much for your support and lights
