Simulation results: force and convergence history
Hi guys,
Currently, the ‘Results Control’ items do not have the functionality to extract or plot the 6-DOF translations or rotations over time (currently we can only get the variation in center of mass, linear velocity and angular velocity from the log).
I believe this can be added in the upcoming platform updates.
But for now, it is very much possible to plot the translation and rotation motions over time by locally post-processing it in Paraview. This can be done using the filter ‘calculator’ for the object surface to calculate the displacements or rotations using formulations (would be slightly tricky for pitch angle) and then plotting them over time using the ‘plot variable over time’ filter.
As an example of what you would get, see this project “Pressure relief valve analysis with 6-DoF motion” and the last figure showing the ‘displacement over time plot’ for the valve’s bottom surface.
So if that is similar to what you need then it can be done with Paraview for pitch angle also.
Ali
