Simulation result in paraview does not have blocks
In this project https://www.simscale.com/workbench/?pid=7755664077313612913
importing the simulation results in paraview gives a blank rectangle.
I suspect this is because I need to hide the surfaces.
However, when attempting to use the “extract block” filter in paraview, I realized that there are no blocks in the simulation result downloaded from Simscale.
What I am trying to do is the use paraview to achieve the things done in Incompressible Turbulent Flow Around a Spoiler | SimScale
How can fix the above black rectangle problem?
Hey there!
I downloaded the results and they opened ok:
You probably didn’t select the boundary patches upon loading. It should look like this:
I see, thanks for confirming that there isn’t a big problem.
I wonder do you see a big rectangular cube when you load the results in Paraview?
For me, I can’t the spoiler mesh inside the rectangle, whereas you seem to be able to.
Yes, what I see at the beginning is the flow region rectangle.
I extracted the patch regions to create the plot above.
I see, really thanks for the hint. I wonder if you care to share more details of how you do it, perhaps like a video? Yours look pretty good!
I don’t see the need for a video, all I did was to use the Extract Block filter you mentioned, thus I assumed you know how to use it.
I just selected the patches I wanted shown:
And colored by U magnitude.
Ah, I see, really thanks for the hints, which helped me a lot!
