I have a question. If my simulation reaches maximum run time before it finishes can you continue the simulation like if it finishes you can add on to the simulation and make it run longer?
thank you for your time,
frank lucci
frank lucci
If you are running steady-state CFD simulations, then that is possible. There should be a button to continue the run around here:
Then you can add more runtime and/or iterations for the simulation:
Please note that community accounts have a limit of 30000 seconds of runtime.
Is the maximum rum time when continuing the simulation the extra time after the simulation or is it a whole new countdown from 30000 seconds?
The overall maximum runtime is 30000 seconds (from the beginning of the simulation).
Ok thank you so much,
frank lucci
