As I mentioned in my other thread, yesterday I run a couple of simulations which came to an end but no results where created. I suspect it can be a problem related to memory management, since I had to struggle with something like that in the past, but I don’t remember how I diagnosed it. My level of french is not high at all so the log file is hard to read for me.
Any hint will be much appreciated.
Alex
Hi @alex_roque
I will look into your project and come back with a suitable solution as soon as possible.
Ani
Thanks @rszoeke for your insight!
there seems to be an issue with result processing for in case you request module+phase results.
If you restrict the simulation output to only real+imaginary representation of the complex results, it should work.
Now you mention this issue I think I faced this problem some months ago, but I think I solved it by requesting only the Cauchy stress in RE+IM format and allowing the rest of the outputs in module+phase. Should I change all the result outputs to RE+IM?
Thank you very much for your insight!
Yes, sorry for that. I guess there is a reason why the harmonic analysis isn’t yet rolled out to everyone - there are still issues we need to resolve, before we are confident to release it.
For the moment you need to stick to real+imaginary results for all fields until the issue is fixed.
Richard
Hi @alex_roque,
the issue is now fixed and all result output types should work again.
Richard
