Simulate the aerodynamics of a towed aircraft
I’ve been interested in simulating the aerodynamics of an aircraft being towed by another aircraft, but I’m unsure about how I would simulate the angle of the rope - I suppose I could first do a simulation without the rope and calculate the lift and drag of the towed aircraft, then use some basic physics to get the rope angle, then move the towed aircraft to that angle I just calculated and try again… However, the wake of the towing aircraft is different depending on rope angle, so this will take many tries to converge to the right angle, and therefore will be very tedious. Is there any better way to do this?
Hi @aperson!
I would say that you can simulate two aircrafts without the rope as the rope would most likely not have a big effect compared to the aircraft. Just vary the angle, a good approach would probably to also already model the fluid flow region so you can place the objects in different angles already in your CAD software and get straight into the boundary condition setup.
All the best!
Thanks! I guess this is the way to go.
