Is it possible to simulate a range of airflow velocities? I’d like to be able to input a range, say, 10-70 mph and see the variations in airflow at different speeds, but I haven’t found an intuitive way to do this. Help!
Hey there, and thanks for using the forum!
Currently we do not have the option for parametric simulations, which means that the desired values are automatically changed and the simulations run.
You would need to manually change the velocity value and start the simulations for each one. Remember that you can run multiple simulations at once and wait for them to finish to retrieve the results.
Fair enough! I had no idea you could run multiple simulations at once, that’s a great bit of knowledge that I’ll certainly put to use in the future. Thanks for your help!
