I am trying to select faces for mesh refinement. There are like 250 faces. Is there a way to select all of them at one rather than clicking 250 times?
Thanks for the help.
Hey @ajaybharish,
you can simply right click somewhere in the viewer and choose “Select all”. This will select all entities of your current picking type (so in case of face selection all faces). If you do not want to select all, you can often just select the ones that you do not want to use instead (if those are much less) and choose invert selection afterwards.
Best Alex
That sounds great!. Thank you very much for the help!
