I have STL file generated from micro CT images for a bone. How can I import this STL file as a geometry and remesh in mesh generation?
Hi @hs6e11!
Simply go to the Mesh Creator tab and upload your geometry there as depicted in the picture below.
Hope that helps!
Hi Jou
Thanks for your reply, I will try
I tried to start new project and import STL file but unfortunately, I could not remesh. Please can you help me how can I create geometry from my scanned mesh?
Hi @hs6e11!
Please let me have a look at it by sharing your project link with me. Simply paste it as a comment and I will come back to you as soon as I have a solution to your problem.
All the best!
Thanks @hs6e11!
Is there an option to smoothen the geometry, meaning that you have a closed surface as well as no “gaps” inside the bone? Which software did you use to export the CAD model?
I am using meshlab
Or Scanip from www.simpleware.com
