The following screenshot shows the faces I want to select as my pressure outlets. Is there a quicker way to select these as there is 340 across the whole model? They are all the same size and in regular pattern across the model.
I have made a topological entity set manually for one of my models however I want to make slight changes to the geometry (that won’t effect the outlets) so want to be able to edit geometry while keeping the entity set. Is this possible?
