I am trying to run les simulation for flow over Naca0012 using WALE subgrid model.I first created the 3-D domain and run the case for steady state case using simpleFoam and then i used the converged solution as initial solution for the les by renaming the folder (6000 to 1e-5) then i decomposed the domain. I am using pimpleFoam for les simulation but the problem is that the simulation is not converging and the pressure equation solver reach the maximum no fo iteration (1000)without reaching a converged solution.
Is there any examples or have anyone worked on les for aerofoil ?
This the RANS results which is set as initial value for les
the velocity fields
pressure fields
after running les simulation for few time step results seems to be not converged
the velocity field
pressure fields
The boundary conditions
u
/--------------------------------- C++ -----------------------------------
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 5.x |
| \ / A nd | Web: www.OpenFOAM.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location “0”;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (71.3 0 0);
boundaryField
aerofoil
type fixedValue;
value uniform (0 0 0);
top
type symmetryPlane;
bottom
type symmetryPlane;
inlet
type fixedValue;
value uniform (71.3 0 0);
outlet
type freestream;
freestreamValue uniform (71.3 0 0);
front
type cyclic;
back
type cyclic;
p
FoamFile
version 2.0;
format ascii;
class volScalarField;
location “0”;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
aerofoil
type zeroGradient;
top
type symmetryPlane;
bottom
type symmetryPlane;
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
front
type cyclic;
back
type cyclic;
nut
FoamFile
version 2.0;
format ascii;
location “0”;
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0.3;
boundaryField
aerofoil
type zeroGradient;
top
type symmetryPlane;
bottom
type symmetryPlane;
inlet
type calculated;
value uniform 0.3;
outlet
type calculated;
value uniform 0.3;
front
type cyclic;
back
type cyclic;
turbulence properties
| \ / O peration | Version: 2.2.0 |
FoamFile
version 2.0;
format ascii;
class dictionary;
location “constant”;
object turbulenceProperties;
simulationType LES;
LES
LESModel WALE;
turbulence on;
printCoeffs on;
delta vanDriest;
vanDriestCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
Aplus 26;
Cdelta 0.158;
fvschemes
FoamFile
version 2.0;
format ascii;
class dictionary;
location “system”;
object fvSchemes;
ddtSchemes
default backward;
gradSchemes
default Gauss linear;
grad§ Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linear;
div(phi,k) Gauss limitedLinear 1;
div(phi,B) Gauss limitedLinear 1;
div(B) Gauss linear;
div(phi,nuTilda) Gauss limitedLinear 1;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DBEff,B) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
fvsolution
| \ / O peration | Version: v1906 |
| \ / A nd | Web: www.OpenFOAM.com |
FoamFile
version 2.0;
format ascii;
class dictionary;
location “system”;
object fvSolution;
solvers
p
solver GAMG;
tolerance 0;
relTol 0.1;
smoother GaussSeidel;
pFinal
$p;
smoother DICGaussSeidel;
tolerance 1e-06;
relTol 0;
"(U|k|nuTilda)"
solver smoothSolver;
tolerance 1e-05;
relTol 0.1;
minIter 1;
"(U|k|nuTilda)Final"
$U;
tolerance 1e-05;
relTol 0;
PIMPLE
nOuterCorrectors 10;
nCorrectors 2;
nNonOrthogonalCorrectors 1;
pRefCell 0;
pRefValue 0;
residualControl //(or residualControl, depends on the version of OF)
p
tolerance 1e-4;
relTol 0;
} // I was said 1e-4 is enough
U
tolerance 1e-4;
relTol 0;
relaxationFactors
fields
p 0.7;
pFinal 1;
equations
“(U|k|nuTilda)” 0.7;
“(U|k|nuTilda)Final” 1;
