Regarding the issue of water vapor humidity emitted by elocity inlet – Chimneys in Smoke Propagation From a Chimney.
DDGS drying emission gas characteristics: high humidity, water vapor, other pollutants, and where to set the humidity of the calculation area. Is there a detailed tutorial?
The tutorial that you mentioned does not have humidity involved in the setup. You can simulate the tutorial with humidity enabled though, but you would need to use a “Conjugate heat transfer” analysis: https://www.simscale.com/docs/simulation-setup/global-settings/humidity-modeling/
