Hello, does anyone know anything like a straight wing or something that someone has tested in real life and recorded the results? This could allow me to see the difference in results based on different meshes.
Thank you for you time and help,
Frank Lucci
There is definitely a lot of experimental data out there for several airfoil profiles (and larger plane models).
If you are looking for something quicker to run, I’d probably direct you to the classic NACA0012 page from NASA. You should find the experimental data if you scroll down (e.g. Ladson force data).
