I’m modeling heat transfer through a double-glazed unit, about [24 mm] overall with a [12 mm] gas-filled cavity, to estimate center-of-glass heat flux. I’d like to capture both natural convection in the cavity and radiation between the panes.
Here’s what I’ve done so far:
• Conjugate heat transfer with a [2D / 3D] model of the glass and gas layers
• Boundary conditions: [interior temp] / [exterior temp] with convective coefficients of [X] and [Y] W/m²K
• Radiation: [not enabled yet / surface-to-surface with emissivity 0.84 on glass and 0.04 on the low-e coating]
My results seem too high compared with a hand calculation, and I think I’m handling radiation wrong. Specifically:
• Is surface-to-surface the right choice for a thin cavity like this, or is there a simpler approach?
• Any advice on meshing the boundary layer in a narrow gap, so the convection cells are resolved without the mesh count exploding?
I’m happy to share screenshots of the setup. Thanks!
Surface-to-surface radiation is definitely the correct choice for this setup. Since the gas in a 12mm cavity does not meaningfully absorb or emit thermal radiation, you only need to account for the exchange between the internal glass and low-e faces. If your heat flux results are abnormally high compared to your hand calculations, double-check that your low-e emissivity (0.04) is assigned to the correct internal face of the cavity, and verify that your external radiation boundary reference temperatures match your convective ambient temperatures.
Meshing the Cavity
To capture natural convection in a narrow 12mm gap without exploding your cell count, avoid automatic tetrahedral sizing. The velocity profile needs enough resolution to capture the circulation cell—flow rising on the warm pane and falling on the cold pane. Use a Hex-dominant or Sweep approach to pack roughly 15 to 20 structured hexahedral layers straight across the gap thickness. This allows you to heavily stretch the cells along the planar height and width with high aspect ratios, drastically reducing the overall mesh count while fully resolving the thermal boundary layers.
