I have designed pipes to flow given a certain inlet velocity & pressure as well as outlet pressure. I want to see the flow of air through the inlet pipes and out of the 9 outlet pipes. When I use Convective Heat Transfer as my flow type I have issues with the mesh. When I use Incompressible flow, I get this as my solution “results”. I want to see air flow through my pipes, let me know what you’d suggest to make that possible
(delete this message before posting)
