When I upload my Car Model, the front is not facing the front, the front is facing the bottom and the top facing right, what do I do?
Hi there!
Are you creating an incompressible flow simulation? If so, then the direction is not really relevant, as you can rotate the model in the viewer or assign the wind flow in any direction.
Hi samuelphillips,
I’ve done what ggiraldof has suggested in the past or alternatively look at your orientation axis/cube and change it before you export from your CAD to match the Simscale default orientation cube.
Ah ok, thanks
