Hi. It seems that there is something wring with the geometry scaling utility. I have uploaded an IGES CAD file (https://www.simscale.com/workbench/?pid=4636557272813855310#tab_0-0) but there is no reaction on clicking the “Start” button under the “Geometry Operation” module!
@roozbehmousavi, I’ve copied the project and this does seem to be the case with the scaling operation. I’ll report an issue. What is also odd is the units: when I download your geometry and then export it from Onshape the bounding box is 9.15 m rather that 9150 m.
Hi, I have the same issue my model is 200m long, I want to scale it down to 20 and if I press the buttons nothing happens.
Do you know already how to fix it?
Hey @roozbehmousavi @pbrandes!
Currently there is a problem in scaling operation. Our development team has been informed and they are trying to fix it as soon as possible. Once it’s fixed, I will let you know.
Best Regards,
-Ahmed
Hey @pbrandes @roozbehmousavi!
The scaling problem has been fixed. You can now use it
Best Regards,
- Ahmed
HI @ahmedhussain18, Great, Thanks a lot!
