I recently did a heat transfer simulation on a model with 25 solid bodies 2kW_V3. The mesh generation went well. In the final simulation results, I found some bodies missing. The body count was right in the i.e. 25 bodies, but i noticed some part names was referenced to the the same physical part. What i mean is that there was only one physical part for multiple part names. The results obtained were also unrealistic. I ran the simulation multiple times with different configuration of contacts and heat sources. I also regenerated the mesh, but all the results had the same problem. I donot understand what went wrong here.
I would be greatful for any suggestions, comments or help.
I had a look at your project and could not find any problems with your parts. Could you maybe explain it a bit further with screenshots? Also why do you think that your results are unrealistic?
Hello @anagaraj,
thank you for reporting this issue! There was indeed a problem in the result conversion process when multiple solids had exactly the same amount of nodes.
The issue has been resolved already by now, but unfortunately you would need to rerun the case to get the full results with all solids.
