i want to simulate the modified design but i cant choose faces (to assign Inlet/outlet) only the whole element.
I tried the surface splitting with feature angle 30 but i still cant select anny faces.
Does anyone know how i can select single faces in that case?
Thank al lot!
Ferenc
Hi Ferenc!
Feel free to copy the updated projects (already split) from here: SimScale - let me know if that helped!
Hi Jousef,
Thanks a lot, now i can choose all the surfaces i want to.
Ferenc
In the modified design I am not able to opt for incompressible flow,only the LBM Method and wind comfort
Modified geometry is still giving the same issue if you have found any solution then please let me know
