in this project i have been trying to run a cfd simulation and i think my mesh is wrog can some one look for me.
“copy new truck wind” is the proect
Hi @sjay
I think it is better to add boundary layers on surfaces of a floor and a car body.
Yosuke Yamamoto
i did
Hi @sjay,
If you look at the meshing log you will notice this.
Undo iteration 0
Checking faces in error :
non-orthogonality > 70 degrees : 0
faces with face pyramid volume < 1e-13 : 0
faces with concavity > 80 degrees : 0
faces with skewness > 4 (internal) or 20 (boundary) : 0
faces with interpolation weights (0…1) < 0.02 : 0
faces with volume ratio of neighbour cells < 0.01 : 0
faces with face twist < 0.01 : 0
faces on cells with determinant < 0.001 : 0
No layers to generate …
Layer mesh : cells:7924616 faces:24008553 points:8160751
Cells per refinement level:
0 449962
1 49012
2 1798665
3 5626977
Writing mesh to time constant
Wrote mesh in = 15.23 s.
Layers added in = 15.23 s.
Checking final mesh …
Finished meshing without any errors
Finished meshing in = 582.26 s.
End
Finalising parallel run
Surface Element Quality Metrics
Area Max: 0.0840737, Min: 3.32753e-05, Avg: 0.005857160694420933
Aspect ratio Max: 5.65687, Min: 1, Avg: 1.2980385234569451
Skew Max: 0.934434, Min: 0, Avg: 0.0005966593537191546
Scaled Jacobian Max: 1, Min: -0.486532, Avg: 0.7023210717088404
Condition Max: 5e+29, Min: 1, Avg: 2.1348467696282437e+24
Volume Element Quality Metrics
Volume Max: 0.0241983, Min: 1.13377e-05, Avg: 0.00147433
Skew Max: 0.843226, Min: 0, Avg: 0.0014932
Scaled Jacobian Max: 1, Min: -0.465943, Avg: 0.999901
Your layers are not being generated. You will need to move to the other meshes where there are layers (check the log as well) or use the parametric option.
i tried to mesh with layers early nd i saw that box behind got a leak and meshed inside
Hi @sjay,
Then you clearly need to fix your geometry in CAD before uploading.
Hi @sjay
How about using ‘GAMG’ for pressure solver.
You are using ‘Smooth solver’ in your simulations.
When I changed p Solver from ‘GAMG’ to ‘Smooth solver’ in my project, that convergence plots got wrong as shown below.
The ‘GAMG’ solver for pressure works fine in my project.
Yosuke
