I see no results (solution fields) after a solution run has solved. Please look at run 3 of this project.
Hi @cschmidt!
Regarding the issue the only workaround at the moment would be to switch to SI units. The team is currently working on the fix. Sorry for the inconvenience. I will keep you updated!
Update: The fix has been released and you should be able to run your simulations with your preferred settings.
Let me know if everything is fine from your side. Thanks for your patience and again sorry for the circumstances and lost productivity.
All the best!
