No mesh option under simulation tree
I am trying the first tutorial of “Laminar flow through pipe” and after selecting “Incompressible” as my simulation I don’t see any meshing option under the tree.
Hi @prghumar!
Did you use the tutorial template?
I have a same problem - no mesh menu item in sim tree - I have tried CFD tutorial “optimalization of a globe valve” and no mesh posibilty. Other project are OK.
Thank for your help.
@Bill_CZ,
Thanks for your message. Can you share the link to the tutorial please? Will check it out!
Public tutorial : https://www.simscale.com/workbench?publiclink=4fb7f192-ab25-42f0-afec-03746dd14ace
(from SimScale Academy course Excercise No 2)
I do not see an existing simulation in that linked project, so you can not see the mesh even if it is there…
To see existing meshes, I had to:
  1. Copy your project
  2. Click on a geometry
  3. Click on the ‘Create Simulation’ blue button that appears in the popup frame (not sure why I could not use the + to the right of Simulations to accomplish the creation of a new simulation where I can view meshes, @jousefm is that a ‘bug’ :question: )
  4. Select ‘Incommpresible’ from list
  5. Click on ‘Geometry’, at which point you can FINALLY see some existing meshes in popup frame :wink:
  6. Then I had to remember to delete the copied project from my dashboard :frowning:
In know, I do not like these new buried meshes either … :cry:
@anon35156959 I hope you see this topic and my tears at the end :wink:
Hi @Bill_CZ,
Thanks for reporting this! I will exchange the link with a new one as soon as possible and the meshing should just work fine! What you can do is to just copy my project with the re-uploaded models:
Cheers and happy SimScaling!
Helped a lot, thanks!
Just fyi: The underlying issue has been fixed in the mean time. “Mesh” should now always be available in the simulation tree, even for old/faulty CAD models.
