I am trying to do a heat exchange simulation using Conjugate Heat Transfer. I have assigned two flow regions (one for water and the other for air). However, I keep getting the error “Multiple boundary condition or interface assignments for the following entities: …” even though non of these faces mentioned are assigned twice. Please find the project link below:
Hi there, thank you for using the forum. This is because you have applied boundary conditions on interfaces. In order to resolve this, you must delete these boundary condition sets. Specifically, I think you set the wrong face for the Air outlet, and chose an interface instead of the flow region’s face colored in red here:
Thanks for the quick reply. It did not help that much. I have recreated a new geometry and things seems to work fine now, the issue seemed to be in the geometry itself.
