Hi there, I’m a beginner.
I’m working on an assignement and I have to analyzing the pressure drops in a globe valve with a water flow.
When I try to run a simulation, it appears the following error: “multiple boundary condition assignments for the following entities: face2@shell_0_face0#0”.
Since this statement, I think the problem is that I used the same surface as a boundary condition for both the pressure outlet and the velocity inlet of water flow.
When I try to change the surfaces, I’m able to select just one surface (the external one); I mean that I cannot select an inlet flow surface and an outlet flow surface to wich I can refer the velocity inlet and the pressure outlet.
Is this a CAD model problem?
Hi there, feel free to add a link to your project too, otherwise it is not possible to get an understanding of the error
Hey @Andrea_r ,I hope you had a great weekend, any updates on this?
Hi! sorry for the absence.
The problem was simple: The CAD geometry was in STL format, wich I discovered is quite tricky. This made the geometry looks like a single-piece solid.
To fix the problem I just added a geometry (add geoemetry operation) and then surface splitting.
Thanks to you and to your collegues who helped me,
Namasté!
This is great, keep in mind that the suggested formats are Parasolid and STEP, and they tend to work better in SimScale
