Multiphase AUV drag force calculation
Hi @cecil_pabbathi,
I think I figured out the problem! So all you have to do is to set your outlet mean velocity to a positive value, which in your case is 3m/s. The negative value of the outlet means flow is somehow stuck and flowing back in through the outlet. I’ve copied your project over and it seems to be running fine so do try this and let me know.
